I request support. Sending the cutting design to the machine, it moves very slowly, marks a rectangle instead of a square, or simply does not move. Thank you
Can you upload the file that is doing this?
I tried to cut a square and the laser marked and cut a rectangle. I notice that the movement of the X axis is very slow and modified
Make sure you checked the mechanics completely before you start (this is not done at factory): Guide to mechanical adjustments and maintenance – Diode Laser Wiki
