My Sculpfun S9 with extension and final switches should cut something with size 570mm in Y-direction. In the preview I see it extending the normal cutting space 400x400mm but on cutting it sizes down to 360mm Y-direction (and also sizing down X-direction of course).
I set $131 both in GRBL (also saving of course) and lightburn to 800mm (“$131 = 800”) but it still scales down. What is my mistake?
Make sure your steps per mm on Y are correct and your rotary is not enabled
$$ in console and paste here all data
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=3
$24=200.000
$25=3000.000
$26=250
$27=3.000
$30=1000
$31=0
$32=1
$100=50.000
$101=50.000
$102=250.000
$110=6000.000
$111=6000.000
$112=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$130=400.000
$131=850.000
$132=200.000
ok
i am sure this values are incorrect
$100/$101 should be roughly 80 i think
Try
$RST=*
press enter
Go back and type $$
Check 100 and 101 then expand again
$131=850
Press enter
Again make VERY sure your rotary is NOT on
that worked!
Rotary was OFF all the time and before also.
Doing what you said changed the values to te following:
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=3
$24=200.000
$25=3000.000
$26=250
$27=3.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=250.000
$110=6000.000
$111=6000.000
$112=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$130=410.000
$131=850.000
$132=200.000
ok
So the steps per mm is fixed? Then this was of course the reason - or do I understand this wrong? The relation between the size of the cutted parts is exactly 80:50
Anyway - thanks for help - I appreciate this fast support very much!
Maybe you was playing with settings or alikes
Remember $RST=* is always a good tool to reset things to default
Glad is worked!
