New user here. I am a having a hell of time trying to get my Longer ray5 5w laser to do any burn through my laptop command. I have ran the $$ command and it appears that everything is where it needs to be.
The test files will burn from the SD card inserted directly into the Ray5 but if I try to burn anything from the laptop command the laser will travel, emit a small of light but not nearly enough to burn anything.
It’s becoming pretty frustrating and I hope someone can help.
Questions
a) are you certain you are using GRBL controller (and not GRBL LPC or M3?)
b) Edit → device settings . Make sure Smax is 1000 - if not rechck a)
c) edit → settings. mm/min? is possible you are still in mm/sec so your machine might be trying to run VERY fast
d) Absolute coordenates in Start from?
Repeating YouTube video results is iffy because there are too many variables. Unfortunately, we see that stuff and then think there is something wrong with our machine when it does not perform the same. What they do not admit is how many hours they spent and how much material was scrapped to get the perfect video.
