<Idle|MPos:-622.500,-622.500,0.000|Bf:127,65535|FS:0,0|Ov:100,100,100|A:S>
How did you change the Origin?
[VER:1.1f.20220810:]
[OPT:VHL,127,65536]
Target buffer size found
[software versions: CV30-Pro-MASTER-Release V1.0.0 20230921-0947]
ok
Retorno a 0
Esperando conexión…
usb connect succeed
usb connect succeed
ALARM:9
Error en retorno a 0. No se pudo encontrar el interruptor de límite dentro de la distancia de búsqueda. Definido como 1,5 * max_travel en la búsqueda y 5 * retiro en las fases de localización.
ALARM:3
Reinicie mientras está en movimiento. Grbl no puede garantizar la posición. Es probable que se pierdan pasos. Se recomienda volver a retornar a 0.
Retorno a 0
ok
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
ALARM:9
ALARM:3
ok
ALARM:9
ALARM:3
ok
Esperando conexión…
usb connect succeed
usb connect succeed
yo no cambie nada y de un momento a otro empezo a hacer eso
- What is your machine workarea size?
- Restart the laser. In the Console window, enter $$. Then copy everything from the window and paste in a Reply.
ok
$0=10
$1=250
$2=0
$3=1
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=1500.000
$25=4500.000
$26=20
$27=2.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$110=10000.000
$111=10000.000
$120=500.000
$121=500.000
$130=400.000
$131=415.000
$150=25
$151=75
$152=30
$157=1
$160=1
$161=9.00
$162=9.00
$163=9.00
ok
400*415 es el area de esta, tengo una creality falcon pro 10w
Ok, now enter ? and Reply.
<Idle|WPos:-622.500,-622.500,0.000|FS:0,0|Pn:Y|WCO:0.000,0.000,0.000>
ok
Ok, one more then we can formulate a fix.
In the Console window, enter $#. Then copy everything that produces from the window and paste in a Reply.
windows no puede encotrar el archivo $#
[G54:-nan,0.000,0.008]
[G55:-nan,0.000,0.008]
[G56:-nan,0.000,0.008]
[G57:-nan,0.000,0.008]
[G58:-nan,0.000,0.008]
[G59:-nan,0.000,0.008]
[G28:-nan,0.000,0.008]
[G30:-nan,0.000,0.008]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Some controllers report like that. I was checking for a work coordinate offset.
Can you Home the machine. If you can, Home it, then report what positions are showing at the top of the Move window.
-622.50x, -622.50y 0z 0u
Try entering this and reHome the machine.
G10 L2 P1 X622.5 Y622.5
If this makes it worse (1245), then enter X and Y with a negative sign in front. I can never which way the polarity should be.
Use zero for X and Y to reverse this if needed.
DONDE deberia poner esos datos ?
DONDE deberia poner esos datos ? en herramientasd e la consola ?
Enter it in the Console window as another command, like $$ and $#.
Esperando conexión…
[OK]system start-up CV30-Pro-MASTER-Release V1.0.0 20230921-0947
usb connect succeed
ok
[OPT:VHL,127,65536]
ok
Retorno a 0
ALARM:8
Error en retorno a 0. El ciclo no pudo borrar el interruptor de límite al retirarse. Intente aumentar la configuración de retiro o verifique el cableado.
ALARM:3
ok
Proyecto cargado en 73 milisegundos
ahora esta en cero pero continuan las fallas
