Second pass over part of an image
I’m engraving a photo on 3mm basswood. (original photo below and engraved photo below). I’ve done several tries adjust contrast, brightness, etc., but the heron (bird) isn’t really standing out from the background. What do I need to do differently? Is it possible to do a second pass over just the bird, if that would make any difference?
The engraved photo isn’t quite as dark as it appears here. Oh, I’m using grayscale at 3250 mm/min and 32/2.5 max/min power.
If you’re able to separate the bird from the background, or mask it, you could do a second pass. That is as long as nothing has moved. I don’t know if that would make things any better or make it worse.
I’d just start with a new one. I’ve put a coat of resin on it now to see if it helped any. Is there a way to put the bird on a separate layer in Lightburn or adjust just the bird without adjusting the whole photo? Would maybe be helpful if I could adjust just the birdSorry if that’s a dumb question. I’ve got photoshop on the brain.
I also have line interval at .085 and 300 dpi. Does that need to be changed? (Using Falcon 2 Pro 22W laser, btw).
Right click on the image.
Click on adjust Image
Slider on the right side for ENHANCE radius and Enhance amount.
Play with the sliders to get a better separation of the fire ground and the back ground.
Try Top slider to 50-60%, bottom slider to about 40%
Thanks for the suggestion. Sure made a big difference in the preview. Will try the laser again.
Thanks for the suggestion to move the enhance sliders. That really made a big difference. Still couldn’t get the clouds in the sky to engrave at all. Maybe something I’ll have to fix in photoshop. Looks better in person than in this photo. Not as dark.
One more question: It took a bit of doing to get the hanger holes just the right size and placement for 5x7. Is there a way for me to save the “holes” layer so that I can just insert it in any 5x7 that I engrave? Thanks for all your help.
Put the holes on a different layer. Make a frame around the photo. Select the critical parts that you want to keep in relative places. Group them together. The right click and select LOCK OBJECTS.
I have 3 layers in the photo - 1 is the photo, 2 is the cut around the photo, and 3 are the 2 holes for hanging twine. I’d like to be able to save the holes layer so that I can paste it to use with other photos. Is that possible?
Yes. I would link the holes and the outline of the frame into a single object.
Then save the object to your library.
There is no “Library” listed on the right side pane, so I looked under Windows. I don’t have a “Library” option to check (as several LB videos showed), only a “Material Library” option to check. Does that matter if it’s in a “Library” or a “Material Library”?
You will need to create a library, then you can save items to that library.
Can I save the rectangle and holes layer as a lbrn file, and then import it as a second layer after importing another photo for engraving?
Sure, you can make another file to open and copy from, the Art library is my preferred method.
Thanks. I’ll do it both ways. If I can screw something up, I will, so best to have a backup method.
You can also do this and get a different output for foreground (bird) and background.
Fast example:
Preview:
FO_B.lbrn2 (2.4 MB)
Well, that’s cool! How did you separate the bird from the rest of the photo? Is there a topic or tutorial somewhere that gives instructions?
  • Just remove the background https://www.remove.bg/
  • Past the bird image onto Lightburn and do 2 or 3 duplicates of it as a backup.
  • Do a rough trace that grabs more or less the outline of the bird (zoom in on the Trace window, fade image and sketch trace, a bit trial and error).
  • Select and Ungroup then select the shape that best outline the bird, after move that shape away from the remaining inside “trash” shapes.
  • Correct the green area with a line and the Trim Shapes tool.
  • Put the original image in the project and do 2 or 3 duplicates as a backup.
  • Align the above outline shape with the bird.
  • Use the Cut Shapes tool and move aside. Now you have an image with a hole in place of the bird and the bird. (do 2 or 3 copies as a backup of both objects)
  • Ungroup the object with the bird image, select the bird image set to another Cut/Layer and adjust bird image, group again. Now you have 2 independent images each one with their own Layer.
  • Place the bird in the hole and zoom in for precision placement.
  • Set power/speed and check the output.
If you get a shape like this
you can simplify the operations by Grouping the shapes and offsetting them with the Offset Shapes tool
Less inner shapes to remove
Ungroup and select the outline move aside and apply an Inward Offset the same amount as before to get the outline near the original.
You have picked the most demanding thing to do with a laser…
The simple problem here is that the photo goes from very black to white. Most materials won’t allow much of a range of grayscale.
This is also why we use a dither, much like a newspaper, we use these dithers to allow us to do away with a grayscale and replace it with very similar gray by fooling the eye with burned areas.
What interval you choose can greatly affect your results, so pick it carefully. I suggest you take the time to watch the Laser Everything photo engraving… well worth your time. Even though it’s done on a fiber laser, the same process works for any laser on any material.
Good luck
