I purchased a Max 4 to go with my Max 3. I’ve not been able to find configuration data for the 4. If someone would be so kind as to share theirs, I would really appreciate it. I also have (NIB) the rotator. If you happen to have the same, that would be a bonus for me.
Charles
I have just sent the file to your email that I use. It also has my Neje Chuck rotary set up on it.
Should also mention that this is the configuration I use for the rotary so you may have to turn off “Enable Rotary”. I also use “Current Position” when using the rotary and Absolute Coordinates for everything else.
I hate to be the village idiot, but is there an email here in the forums I should look for?
My business email is: teelshandcrafted@gmail.com if that helps.
What you have is exactly what I need, and I appreciate your help!
I’ve just emailed you the lbdev, lbprefs and lbset files using the email you provided. Let me know if you get them.
Perfect! Thank you, I have them!
