Hi all,
I’m using an xTool D1 for repetitive production of the same pattern. The xTool has a physical button to automatically run the loaded pattern that I’d like to use. It seems like “Send GCode” is the correct approach, but this isn’t enabled in Lightburn (either xTool’s LaserBox or Creative Space will load the pattern into the D1’s memory and enable use of the physical button).
Is there a workaround for this? And for lasers without “Send GCode,” is LIghtburn sending the GCode in real time?
Thanks!
