Hi,
I missing “Set Finish Position” in my software - in the online manual it should be possible to determine where the laser head should run when a job is finished
software version 0.8.06
Hi,
This is only for GCode based machines. If you have a Ruida controller, the controller itself determines this. In general, if LightBurn is not presenting you with an option, it’s because it is not supported by the controller. You don’t have a console window or overscan settings for the same reason.
