Hello.
Is there an option to show/hide the icon of the “Set Laser Position”?
Everyhting is fine (sort of say), but when I click in the workspace does not show the small icon where the laser is located
Not sure that I am following. Are you asking about hiding this “Set Laser Position” icon?
There is not currently a way to hide this icon, without hiding all the ‘Tools’ in that bar.
Click to Move tool
Hotkey = Alt+L
The Click-to-Move tool is a quick way to jog your laser to a location somewhere in the workspace. Select this tool, then click anywhere on the page and LightBurn will issue a command to send your laser there. This tool automatically turns itself off after about 10 seconds, in case you accidentally leave it on. Trying to select a shape and having the laser move away from where you want it can be confusing.
You also might be referring to,
Show Last Position
When enabled, the Show Last Position button places a cross-hair cursor in the edit window at the location of the laser head. If you jog the laser within LightBurn using any of the positioning tools, the position will be updated. The position does not update live - for example, it will not update while a job is running, because that would encourage you to watch the screen instead of your laser. A laser should never be left unattended while running.
