Just noticed that the “button” tap to set origin in the move window is missing, I have tried different things even set to default settings, any help would be much appreciated.
Provide the following please:
- full screenshot of LightBurn with Move window in view
- push Devices button in Laser window, click once on the name of your laser, then take a screenshot
Didn’t realize that when you put Lightburn to beginner mode, it takes the set origin tab off. All Set now. Not sure why the would disable that function in the beginner mode, That has been so useful to me as a beginner.
Not sure of the exact rationale but use of User Origin would definitely not be a beginner function given how abstract the concept is.
Bonjour, je traverse le même problème. J’ai enlevé et remis le mode débutant mais les boutons “origine” ne sont toujours pas visible. D’autres idées? svp
You need to do the opposite. Set Origin is apparently only available if Beginner mode is disabled.
Also, I’m not familiar with your laser but if it’s DSP based it will never have a Set Origin button available in LightBurn as that’s not an available feature for DSP.
