Hello. I have a (maybe) simple question:
I have a object with 14 layers. Layer 1 to 12 should have the same speed and power. Can I select layer 1-12 and set the value for speed and power for all layers at one time?
Regards
Regards
You canāt, no. Why do you have 12 layers with the same speed & power settings?
LightBurn does not currently allow multi-select of Layers, so no - not the way you are thinking at this time.
If you are going to use these settings regularly, once set, you could define these settings as the āDefault Layer Settingā for these layers and new work will use them.
Thanks for your fast responses.
I have a new Ortur Laser Master 2 (20W) and I am testing actually a lot. I am having some Problems with the focus. So I am lasering a ramp with different distances between the object an the lense.
Maybe I am the first and last person on earth who will need 12 layers with the same power and speedā¦
Regards
now you make me curious what your ramp test looks like, do you want to show it here as a lb file?
I am very unhappy to dissappoint you, but my ārampā is just a 3mm wide line.
The object is askew to the groud. So I start with a difference at 10cm and go up to 1cmā¦
ok, iām just confused about your 12 layers and wondering how they are used for a ramp test
