Set up coaster template that worked. Next day it was not in the same spot
I am using Lightburn with the Longer Mini 5 laser. I had set up a template cut out in leather that I mounted on a wooden board. The coaster hole was cut out and then I just drop in a new coaster and print. This worked for the first day. Next day, I pulled up the exact same file and now all of a sudden it is 2 inches off and I have to move the image around on the layout to try and get it to go to the same spot. Any idea why it moved? I did not change any setting and used the exact same file. Any help would be greatly appreciated.
When making a jig, be sure to HOME the laser and index your jig off a known and better yet, solid reference point. Lock the outline in place on the LB workspace.
Perhaps:
If none of those help, then it seems there are many ways to be misaligned and only one way to be aligned. More details about the setup you’re using will be helpful in figuring out what’s going wrong.
Edit: Add don’t move by hand
