Anytime I open a file to cut, the setting automatically defaults to $32=0 which leaves a traveling line on the fabric I’m cutting. Is there a way to make the $32=1 the default setting so that I don’t have to remember to check or reset it every time I open up a file?
When you set that GRBL parameter, follow with $$ in the Console window to confirm your controller accepted it.
Some manufacturers lock you out. If you bought it as a laser and $32 will not stick, the manufacturer is your only hope.
