Hi,
Where can I adjust time for open air valve (0-1000 ms) before laser fire!
So I wanna open air valve 0.5 - 1 sec each time before the laser begins to cut the selection, is there an available option for this?
Also for delay after cut!
thanks
Hi,
thanks
Air assist is controlled for the layer so to do what you are requesting, you may be able to leverage the Start and End pause time with the power set at 0%:
Thank You, it works
