Setting HOME to X0 Y0 using EleksMaker Mana SE
I cannot get the Home position changed from X600 Y0 to X0 Y0 on my EleksMaker Mana SE.V3.2. When I tap Home the laser moves left trying to go to X600 and crashes at the right end. I cannot stop it without turning the power off… The jog arrows do not work at all…
Firmware is Grbl-M3 1.1e.
Laser work good using T2Laser software. I would like to buy Lightburn which offers more flexibility.
Which profile did you choose when setting up LightBurn? For your firmware, you will want to pick the Grbl - M3 profile. Where do you have the Machine Origin set?
This is worth review: Common Grbl Setups - LightBurn Software Documentation
And here is another great resource for your setup. elekslaser_a3_pro | EleksMaker Wiki
I have laser set to GRBL - M3 (1.1e or earlier)
Origin is set at lower left
