Setting LB $30 Device settings
I’ve looked around and watched the videos that talk about the $30 g-code command about Spindle Speed…
It refers to setting the Machine Speed setting to that in LightBurn
so they match and when you set your Power to 50% in LB it matches that in the Machine Settings…
It was a good video but the RUIDA does not do the Console G-code…
So it must have been on a Laser that had a different controller…
Ok referring this to as laser power instead of cnc drill speed, is what they are talking about,
The video I watched actually shows the S30 in the Machine settings and the Device settings
I have a Monport 130w Ruida controller and when I look at the Machine settings, I assume it is under the U-Axis there is nothing about Spindle Speed or S30 but did find a Power setting, so I have to assume this is it.
Now in LB the S-Value MAX setting is not found…
anyone run into this…
That option is available to GRBL based devices.
Are you saying the Spindle speed is available to ONLY grbl devices ?
I know the S30 code is not on the Ruida as I stated…
You don’t have to care about all this. As parsec mentioned, this is for grbl-based devices. Those were developed initially to run CNCs and were adapted to lasers. And they base on a different hardware design. Ruida controllers are laser controllers that do not have / need that option.
Yea I understand that…
here is the video that explains a possible system power discrepancy, and I was just curious to understand the spindle info
ck out timestamp 1:40
This still doesn’t apply to your laser. Anyhow, I described the background of this setting here (s-value max section):
ok I need to think on this
Hello sir, me too encounter this very problem. Can you tell me what are the solutions? Thank you
Nash…
Not sure of the solution, still investigating if this applies to CO2 lasers…
ok , Thank you. Let me know if you got anything on that.
It doesn’t, at least for CO₂ lasers with Ruida controllers, simply because they do not use G-Code and, thus, do not have an S command to adjust the spindle speed / laser power and lack the entire list of $ configuration parameters.
I figured that since the Ruida did not support gcode…
but thought there might be a Spindle config item…
Rabbit holes… :slight_smile:
Is there a particular problem you’re solving for? If so, please share and someone may be able to direct you to a more specific rabbit hole.
Not a specific issue, new to lasers and was following up on a video discussing the mismatch on the $30 spindle values that could cause power discrepancies.
Was not sure if it applied to CO2 lasers… curiosity…
The relationship of power to spindle speed in GRBL is predominately a legacy vestige to GRBL’s origin as a CNC controller.
Ruida controllers are purpose built controllers for laser function. There are related concepts that can control min/max power or narrow the accessible power range on these commodity CO2 lasers and are fairly well discussed in the forum if you are curious.
