Setting up Lightburn to CNC Machine, Not Laser
I have an issue setting up my Fox Alien CNC machine to Lightburn. I have been using Lightburn with my XTool Laser but I’m trying to get the software to recognise the Fox Alien CNC. I have the USB connected and machine turned on, When I Googled how to setup Lightburn to the CNC, it wanted to give me a mess of how to’s for CNC’s with Laser’s. Any Ideas would be appreciated. Thank you.
Have you set up a new device?
Lightburn has a CNC switch in the Device settings window.
You do realize Lightburn is not a Zaxis feed program?
Yes, I turned on the CNC switch, but the CNC does not show up in the list of devices. I want it to show the CNC in devices and make it work using Lightburn.The only devices that shows is the laser which is a different machine from a different company.
What are you trying to do? Set this machine up to laser?
You cannot use it as a cnc in Lightburn.
If you want to change from cnc to lasering you will have to create a second device by clicking on devices in laser window and adding manually.
