Setting up Toocaa L2
Just new to laser. Received my Toocaa L2. Set up was good and everything worked out of the box. I then researched Lightburn as an operating system. Signed up and am in the trial stage.
Lightburn has a “Find device” but can’t find my unit. Opened manually find device but doesn’t have the Toocaa L2.
What do I do? Any help is appreciated.
You should have received a memory card with your machine. There should be a file on it named *.lbdev. Drag and drop that file onto the Lightburn screen and it will install the necessary info into Lightburn.
Thanks Tim. All is working. Appreciate the help.
