I have an Xcrave 1000mm and the area of my waste board is 29.5 x 29.5. When creating a job how to a set of the work surface to be engraved? I have tried changing the work are to the piece of wood I’m engraving but it is sometimes near the edge of my waste board.
The LightBurn Workspace is typically set during the initial setup process to match the physical size of your hardware. This is done once and once set correctly, you should not need to change again.
