I’m trying to set my material libraries with a cut offset of half the material thickness so the focus will be in the middle of the material, a defocused engrave setting (along with a regular engrave setting), and a mark setting focused on top of the material.
There are several materials of varying thicknesses, so the material-thickness parameter is set for each material in the library.
The machine has autofocus that works very well and I want to keep using it.
Is this possible?
While trying to fix issues I came across several other posts here of people having the same problems and none appear to be solved.
The two main issues appear to be LB ignoring the material thickness setting altogether, or adding the material thickness each time a new job is started (this seems like a bug).
Anyone figure this out?
