Setting ZERO in offline mode
Made a fixture to hold 4 cap patches. They’re spaced in a 4" grid pattern on a plate. I’d like to pick up the crosshatched center of the plate and burn 4 patches in one setup. I can’t figure out how to set the ZERO on the crosshatch then burn 1-4 patches from that starting point. Any help is appreciated. Thanks!
Michael in TN
where do you want to start from?
You’ve probably made yourself a template, I typically have my starting point in the top-left corner, that’s also where my machine’s origin is.
If you choose “cut selected graphics” you determine what should be engraved/cut.
Should I have misunderstood, try again.
