Settings change when sending a file over using USB cord
I have a 150w c02 laser. I am using lightburn to run my designs through. I’ve attached my roller type rotary and when I send over a design from my laptop (connected through USB cord) my speed setting always changes to 1000. Even though I set it for 150 and sent it over.
Not knowing what controller you have, I’m just guessing. I believe most all of the DSP controllers run in mm/sec. You most likely have selected mm/min or something else in your LightBurn settings. This can be changed in Edit/Settings as circled here:
Ok, thanks, I will check that out
