Settings changed and laser will not work
Recently the default speed and power changed for all my projects and for new ones, if I change the settings the laser travel is a lot wider and will no fire correctly no matter what the power is.
In what context did this happen?, have you updated LightBurn or what have you done?
Normally all machines have their own profile, with all the relevant data such as dimensions and speeds etc. This data is stored in a settings file.
If you find it from an automatically generated backup, which LB does, you can download and import it.
But that will not explain what has happened to your system, i.e. what caused the error.
I just recently paid for the activation and it was working perfectly with the trial and it work for about a week after I installed the update. then one day I turned it on and it showed 232/10 speed and power for all saved projects and new ones.
What unit of measurement are you using? Are there any other changes besides your speeds? I assume your power settings haven’t changed.
It has nothing to do with paid or trial version, your basic unit of measurement has changed for some reason.
