I’m trying to cut a mix of holes and thin engraved relief lines on 1mm basswood.
I have one SVG layer for the holes and another for the relief cuts.
For the holes, I’m using 10mm/sec speed with 90% power and air assist, and it cuts fantastically.
For the relief lines, I’m using 10mm/sec speed with 1% power and air assist, but it still cuts straight through. Complete overkill. If I set it to 100mm/sec speed, then that effectively reduces power enough to engrave the lines, but the lines have a lot of slur, wobble and inaccuracy, making the result look terrible.
How do I reduce the power of the laser without increasing speed and ruining the accuracy of the cut?
You may find 100 mm/s = 6000 mm/min is overly aggressive for a tabletop diode laser, particularly if you haven’t yet verified all the mechanical tuneup items:
There’s a considerable range between 600 mm/min and 6000 mm/min, as well as 1% and 90% power. When the extremes aren’t working, the Material Test results may suggest a more suitable combination for each purpose.
