Hi, can anyone tell me what the setup settings for the laser GRBL for using LightBurn and how to do it? I am trying to get LightBurn to work with my laser machine so that I can burn images and write text and so on. I am very new at this. I am not that young anymore so bear with me. (retired) Thanks in advance for any help you give me.
What kind of laser do you have?
Here’s a guide for installing LightBurn:
And adding a laser:
Here’s a video guide on setting up and running a first-time project with a GRBL-based diode laser. Even if it’s not the exact same laser as yours, the steps in this video will likely be very similar or identical to the steps you’ll take with your laser.
Thank you. The laser is by “TwoTrees”
Two Trees TTS Laser Engraver 5.5W Laser Engraving Cutting Machine 300x300mm N7R0
You’re welcome! Let me know if you have any questions after reviewing those resources- they should get you on your way with your Two Trees.
