What settings are you guys using for the Norton white tile method of engraving on ceramic tile?
sorry but you have to find your settings by yourself, like we all have done
mine settings won’t fit on your laser, like @Bulldog 's ones doesn’t fit on my machine
I can give you maybe a starting point but you did not say what wattage machine you have. My machine is a 60 watt co2 laser and my settings are 30 mm/s and 40 percent power. But that 40 percent power can vary greatly from machine to machine. I forget what the amp reading is but I adjusted my PSU to output the proper amps at 100 percent power.
Thanks Glenn. I have a 90w laser. I downloaded a test grid and did first ones. Got a good base to start with.
