I find that my 10 W diode laser will not engrave on brass. Are there settings I can use to get this working?
To find out whether to engrave on brass or not, I would use the “Material Test” tool with the laser properly focused on the material you intend to engrave.
This way you will be able to obtain the best settings for engraving with your machine because the settings change from machine to machine.
In short, no. A 10w diode laser will not touch brass for engraving. It can mark with a marking liquid, but it will not directly engrave brass.
Thanks a mil James. Appreciate.
