Setup for a FoxAlien 4040-ex 20W Laser
Hello,
I am inquiring on how to setup my FoxAlien 4040-ex Laser using Lightburn. Not sure what the settings should be, and can’t seem to find the specific answer I need looking through the forum. Can someone direct me please. Thanks!
Does Lightburn recognize your laser in device list?
What settings are you referring to ? If its setting up, FoxAlien use a standard GRBL controller and it is set up as GRBL, if it is other settings like engraving or cutting the only way is to run material tests for the different materials you will be using.
