I downloaded the new update today and when I down a cut, it created a shadow on the work I was doing. I can’t understand why it’s doing as it’s not done it before. I forgot to mention the shadow was of what I was cutting.
Chances are you have something on your lens, or the beam is hitting an air-assist nozzle and reflecting off that.
If you draw a single circle and run it as a cut, and the cut goes around it once and stops, but you see that shadow, then it’s a physical issue. There’s nothing in LightBurn capable of making the beam hit two places at once - it would just be a coincidence that it started after the update.
