Shape Properties not displaying the correct values
Windows 10/LB v1.2.04
Error is reproducible (Purchased file - source design software unknown)
When using the Shape Properties (SP), I found a peculiar error.
Selecting a single rectangular shape, I get measurements in SP that are nowhere close to the actual size. But in the Width / Height in the upper left, they are correct!
The 2.328mm x 26.538mm dimensions are correct, but the 8.800mm x 100.300mm are not.
I can send the file if needed.
I can draw a new rectangle with the correct measurements and click SP, and the measurements are perfect in the SP window.
I’d appreciate your thoughts! Thanks for listening!
JoeG
