Hello, Lighturn community. I’m working on upgrading a shapoko 2 with a J-tech laser. The firmware was 0.9 I did the upgrade to 1.1f, the laser is mounted and soldered in. I have a couple of issues that I can’t seem to figure out. Starting lightburn the machine connects I can more the machine but I get an error 9 and can not set a home position for the machine. Also, none of the limit switches seem to engage if pressed. The machine just wants to keep going even when at the end of the tracks. I’m not too familiar with the wiring for these machines. From what I read these issues could be a wiring problem or a configuration problem. I did all the configuration as instructed from this link, https://jtechphotonics.com/?page_id=1100 This is the link I’ve been using for the upgrade and have followed everything they suggested in there. I can’t seem to figure out why the error 9 is coming up and why none of the limit switches are engaging when pressed down. Has anyone done this upgrade that could help with figuring out how to fix these problems? I attached 4 pictures of the wiring maybe something is missing? Thank you in advance for your time and effort.
