Shapes and circles
I have the Longer B1 30 W laser. I have been using it for about a month with no issues once I got the hang of it. For 2 days now the laser has squashed all images and shapes down into oblong shapes and images. I have not changed any settings except for when I had my rotary roller set up. I have looked to make sure the settings have not changed, but do not see anything. I have also, uninstalled and reinstalled the lightburn software but it has not corrected the issue. I have redone the images and shapes but this has ot corrected the issue. How can I fix this issue so stuff comes out correct.
Have you got rotary enabled?
after I was done and disengaged the roller, it does not show engaged in the lightburn software.
Is it disabled here?
yes, it is
If you use a different software, does it still happen? If so, you may have a mechanical problem like loose belt or something
