Shapes not closing
Not sure if this is something in my settings or hardware related. But smaller shapes as seen in the image are not cutting correctly. All shapes should be closed and as you can see some are off. Not really sure what to even look at.
200 mm/min 100% Power / NEJE A40640 Diode
Any help would be appreciated.
Thanks!
This is not a setting, but an issue with the assembly of the machine. Check belt tension, couplings, eccentric nuts, bearings, etc.
Ok, I recently had to move my limit switch when installing a new module. Maybe I set the tension too hard. Thank you.
