Hello everyone,
I’ve fitted a fixed-focus camera to the lid of my new CO2 laser, and it’s fixed in place and doesn’t change position (another camera is also set up for a second diode engraving machine).
On my first diode laser, the camera works perfectly.
On my second laser, I selected my new ‘Ruida’ machine, the settings went well and just after calibration, it was perfect, with no shifting during engraving.
On the other hand, if I quit the software. I restart the application. Without touching anything on the machine, or restarting the computer. I make the acquisition, superimpose my part in the same place, during engraving I have a large offset between the screen and the real position of the laser (about 3 cm on the x axis and a few cm on the y axis).
Have I forgotten to save something? Can having a second camera on another machine interfere when it’s not selected?
I’m a bit lost and redoing the alignment each time wastes time.
Do you have any suggestions?
Thank you for your support
Hi Levier,
Can I ask what version of Light Burn are you running currently?
Also do this for me if I can ask
a) run the calibrations one time → run a test. Does it work OK?
b) right click camera control panel - > Export Camera Settings. Save somewhere n desktop
c) Close and reopen LightBurn. Try a little pattern to see if you have the offset.
If yes
d) Right click > Export camera settings > save as a different name please
e) Right click > Import camera settings > Import the previous saved version
Run test again. Still offset?
If so could you send to support@lightburnsoftware.com both pre and post restart LightBurn export files please?
Hello,
Sorry for my late reply (business trip).
I have followed the procedure scrupulously from the beginning. The camera works perfectly after several tries, software en PC restarts.
Conclusion: I probably made a mistake selecting the second camera.
Thanks for your support, sorry for that.
I believe I was able to reproduce this issue. I sent an email to the support address with the camera settings export files and a full description of the steps I used to reproduce the problem. If any additional testing/debugging is needed, I’m happy to test.
Thank you JD
Question as is the info missing
a) 1.6.01 correct?
b) Help > Generate Support data
Can you paste into a new email to support please?
Hi Gilaraujo,
This information has been sent in an email. Sorry for the delay, I missed your reply here. If there’s any other info I can collect, can you reply to the email as well (I’ll see that sooner)? Thanks!
