Your profile says Smoothieware. If you’re using stock Smoothieware, your maximum speed at 254 DPI will be 80mm/sec. If you try to go faster than that, the controller may skip. Look for the Cluster firmware posted on the C3D website, as it fixes that issue (you can go up to about 240mm/sec at 250 DPI without stuttering)
