Is there a shortcut to change devices? i use my lightburn with 2 machines and it would help me a lot
I installed Lightburn in 2 locations and made links to each program. I have a D drive so I added the second copy of lightburn there.
After setting up multiple devices, you can switch between them by selecting them from the dropdown menu in the Laser window. To set up a second device, click the ‘Devices’ button and you can set up your second device the same as you did the first.
They are both running, I wanted a keyboard shortcut to easily switch between them
