Shortcut to enable/disable ROTARY disappeared
the shortcut to enable and disable ROTARY disappeared in the last update 1.6.03.
Make sure you are not in ‘Beginner Mode’ from the settings dropdown menu
Perhaps:
Make sure show in main window is checked in the Settings window. If you change the switch, you have to restart Lightburn to make it appear in the Laser window.
