Hello! I am using the perforation to create a dashed line on the inside of my rectangle. (See attached screenshot)
Is it possible to make it so that all 4 corners have both a vertical and horizontal line in the corner? See where the bottom right corner only has a horizontal line?
I have been playing around with your question and I have this suggestion. Draw your 2 strokes in a corner so that they hit each other if that’s what you want and afterwards use the distribution tool with the measurements you want. It showed example, took me under 2 minutes to make.
I’ve been playing around with the distribution tool and i’m not sure how to go about how to use it. It seems to just stack things on top of each other for me.
