I want to know if it’s possible to show the exact position of each element before the cut starts.
Why i want that, is because i want to first paint the MDF and after that cut, as it’s easier to do it like this, for me.
So i know you can select “Frame” but that give you like the big picture, i would like to see exactly where each piece is, as they will be of different colors.
Is that possible? Or maybe it will be implemented in the future?
Thank you for your answer.
Was thinking about that. And i assume i will need to also increase the speed so i don’t have to wait a long time.
Ok, that makes it clear, again thank you for answering.
Yeah yeah yeah. I already used it for cutting, as i said, i feel it’s easier to paint like 2cm wider directly on the MDF and then cut, then cut all the pieces, then paint them.
For cutting i already have it all setup. Will at 5% leave any mark, if i set the focal point to the surface of the board? I mean i don’t need it too, but just to be sure. I was thinking maybe speed of 3000mm/m
