When I cut in line mode I get the cut lines showing. Some suggested to type $32=1. When
I did that the laser went through the motions but never burned anything. Any help would be appreciated. just got my FoxAlien 4040 LE yesterday.
do you have restart lightburn ,after setting $32=1???
hmmm, let me try that
thanks
$32=1 enables laser mode, which also enables ‘Variable Power’ mode. If it doesn’t burn with that on, it most likely means you tried to run the job faster than your laser is allowed to move. Read through the bit under the power/speed graph here: Configuring a 3018 CNC (or other CNC-based laser) for use with LightBurn
