Showing the laser position - solution
I found interesting to tell how to light laser position at table. If you want to see point at your work table you should use GRBL commands:
  1. Laser on → M3 S5
  2. Laser off → M5
    Adding those command to tab console Macro 0 and Macro 1 like I did.
Or you can just click the Fire button in the Move window.
Thank you for another approach.
I think 3% is a bit high. I use 0.5% on my 10w and 40w/20w lasers.
Do you have a 32 bit controller?
Do you use googles when framing at a low power settting?
