Since 2.0 install console is constantly scrolling while idle
I did the upgrade to 2.0 the other day and ever since there is gcode? constantly scrolling on the console screen.
You might need to change the com port or restart the connection. Usually this happens when „enable dtr signal“ is set incorrectly, maybe it has been changed during update.
well I tried a new com port and also enable/disable dtr signal. I did not have this issue before the upgrade to 2.0
Then check this:
This is more likely the cause then.
