Tengo una LM2 S2 que después de cortar no se apaga el sonido del aire, ayer que instale y compré por fin la licencia de la nada se comenzó a apagar solo como debería ser pero hoy ya no, como puedo hacer para que después de cortar se apague en automático?
I have an LM2 S2 that after cutting the sound of the air does not turn off, yesterday I installed and finally bought the license out of nowhere it started turning off by itself as it should but today it doesn’t, how can I make it so that after cutting it turns off turn off automatically?
If you are talking about the cooling fan on the laser head, Lightburn does not control that.
If you are talking about Air Assist, M8 (or M7) turns it on and M9 turns it off. You control it in the Cuts/Layers window. If it does not turn off at the end of a burn cycle, enter M9 in the Console window to see what happens.
me refiero al ventilador del láser, este no se apaga, hace 2 días se apagaba solo pero ahora ya no lo hace y no se como solucionar ese tema
The laser cooling fan, if it turns on and off, is likely controlled by a temperature sensor. My Sculpfun S30 Pro has the fan running whenever power is applied.
