Hi there,
I’m facing two problems with lightburn that are related to size and measurements.
1- when i import a PNG that i worked on in Photoshop the imported png differs in size that what i worked in Photoshop. i know that PS is raster based while LB is vector based i assume but i worked with other programs for other machines that didn’t have that issue.
2- LB mm system is busted for some reason. i can’t change the size of something meaningfully, for instance, if i changed the size from the bar above to what i want in mm, say something is 10 cm big so i enter for X 100 mm and cast it, it would actually size close to 24 cms and so on…
i hope that there’s a simple fix for these “not so bright issues” im facing
thanks
i don’t understand very well what is your issue, you mean that a line made with PS (assuming is 50mm long) imported it in LB is 100mm bigger? or when you engrave it is 100mm bigger?
Oh but the dimension issue is not solved tho… i think i didn’t explain it that well so lemme try again…
Lets say i imported any object in LB, it would appear at a certain size with x and y dimensions.
If i wanted the X dimension to be a certain size ex: 5 Cm which would translate to 500 mm right?
When i change the x to 500 the size would be much bigger both in the program and in the laser shape cast.
I assumed it measured the dimensions in radius rather than diameter. But still it appeared much bigger than what the numbers said.
The number above would still be 500 or 250 but when measured IRL its much bigger.
I know it’s probably a mistake on my part and not the software’s fault. But after alot of head scratching i still cant figure out what im soing wrong.
I’d be glad to provide with any information needed.
