just updated to version 2.1.02
now when i resize the image im about to burn the percentage stays at 100% instead of changing to what ever value i set it at raise or lower, either by directly typing in say 50% or by changing the the mm readings it will still show 100% even though the image did actually resize from original and it seems to forget what the original 100% size was as well.
I may well be wrong, but I think that has always been the case.
You can scale up or down but afterwards it will always show 100%
It doesn’t maintain the original size in it’s calculations and show the percentage of original. When you scale any image the new size is 100%. This is normal behavior.
If you want to be able to experiment with different scalings from original, undo 1 step and input the next scale you want to attempt. Repeat until you find the result you’re looking for.
In other words, scale 95% (not enough), Undo, Scale 90% (still not enough), Undo, Scale 85% (Perfect).
