I am trying to import a dxf file from Sketchup, but unfortunately when imported into Lightburn the file shrinks significantly. Is this a known problem? If so how do I fix said problem?
DXF files are notorious for not storing their units with them, so if you created the file in inches but loaded as mm or cm, it could be 25.4 or 2.54 times smaller than intended.
You are a genius, thank you so much for your help.
FYI anyone else that reads this you need to save the file as a 3d model DXF
