I don’t think my issue is lightburn related but I thought I would share to see if anyone else has seen this.
The beginning of rectangle fill is skewed slightly but corrects itself by the 4th or 5th pass. See picture.
I just got the laser together and am trying to dial in my settings. I also tried this same file in lasercad and had the same result. I tried with multiple speeds and multiple power settings. I tried different areas of the table and different size rectangles, all the same result exact result.
You can see the lines are the correct length, they are just shifted slightly on the first few passes.
