I am trying to make some Trapezoid shapes. What i normally do in Illustrator is get the Direct selection tool, select the top corner and then use the Skew tool to drag them in closer.
I currently in LB just use the Node tool and just drag them in. Is their a method to grab those node corners and skew them together, perhaps even type in the amount of skew?
You can drag-select nodes in Edit Nodes mode, and then use the cursor keys to move them together. Is that sufficient? We do not have Skew drag handles at this point.
