Hello… So I seem to have a problem with my engraving… Recently my board went out so I had to replace it and ever since I did I have been having problems with engravings having skipped spots… I’ve attatched a photo… Before I was able to run my engraver at around 2800mm now I have to slow it down to about 1500-2000mm to get a clean even burn it is not always every engraving either sometimes they come out fine but others do not even in the same burn cycle… I have a 15w laser running GRBL 1.1f and these are the settings currently on it… I have checked to make sure the Baud and what not are correct along with $30 matching the S-Value… Oh ALSO, the fan on my laser is now always on… before it would only be on when engraving… Idk if that helps.
$0=10
$1=25
$2=0
$3=5
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=100.000
$25=1000.000
$26=250
$27=1.000
$30=255
$31=0
$32=1
$100=80.000
$101=80.000
$102=80.000
$110=4000.000
$111=4000.000
$112=6000.000
$120=800.000
$121=800.000
$122=5000.000
$130=400.000
$131=300.000
$132=200.000
