I designed this to be a paintbrush holder for small paintbrushes. When I ran this, I got what you see in the attached picture, I have marked some of the skips, so you see what I mean. Also I ran this twice in the same spot pretty much, with the same results. As you can see, I have my settings slow. Attached is the G-Code for this project. Can anyone help, please? P.S. I hope the photo and G-Code works.
Perhaps Tabs / Bridges
are inadvertently turned on:
Thank you ednisley, I’m fairly sure that was the problem. I looked and the tabs were on. I am in the process of re-running it to check. I’ll let you know
It seems to be a very common problem, which makes me think that toggle switch shouldn’t be quite so easy to flip.
